70 chevelle sb, mini starter. The gear on the starter does not retract far enough from the flewheel. Pulled starter apart and put in a shim to slide the mounting block out 1/8 inch about. Has anyone seen this before? Is this something dumb that i am missing. Tracy
Had the same problem when I replaced the original mini-starter on mine. Come to find out, the mounting block bolt holes on the new starter were cut farther away from the edge of the mounting block. Had to swap out the mounting block on the old one, and everything was right with the world..........You might want to measure the holes on yours........just in case.......
spoileddaddy
