1 - 2 of 2 Posts
Would like advise on tilton style or mini starters.pros or cons.How do I tell which starter I need.153 or 168 teeth?starter bolts straight across.one long and one short bolt.sbc w man trans.69 chevelle.
I'm using a factory gear reduction starter, it had years of service on my old small block, and is currently working great on my 540. Can't remember what application you should ask for at the parts store, but it came off a newer style chevy truck I believe. I bet somebody here can tell you what application to look up.
Also, if your bolts are straight across, you have the 153 tooth flexplate.
1 - 2 of 2 Posts
