1 - 1 of 1 Posts
Just thought I'd share a tip/trick I used this morning.
I'm not going to open the "Can of Worms" about starter heat-soak again, but it happened to me last night. No "click" from the solenoid. About the time I got a buddy and a tow arranged (1 hour) just for ghits & siggles I turned the key and vroom! It had cooled down enough.
Anyway - after cussing up a storm getting the starter out from between the tranny cooler lines and the headers (using a pry-bar and kicking myself at not notching the holes for the heat shield I made)I rebuilt the thing.
BTW - NAPA/Echlin brushes are part #R503
Time to go back in. I can't pry the header away the 1/8" I need with one hand, and shove the 25 lb. starter up the hole with the other. I need some way to move the header and keep my hands free.
Using a ratchet tie-down strap I found a couple of convenient holes in the frame, looped the strap around the offending header tube and gave it a few cranks. It gave me the clearance needed to slide the starter right up in the hole.
Reconnecting the wiring is another story!
Thought I'd share.
1 - 1 of 1 Posts
