i change the starter on my small block and dont start
i conected the battery cable correct but the 2 little wires i might connected them wrong. does it matters where they go or the white and the black have to go in sertain way?
thanks
all help is appriciated
The small white or yellow wire goes to the points coil from the "I" terminal on the starter. The heavier gauge one goes to the "S" terminal.
I think the "I" terminal is the one closest to the block. If you don't have points ign. You shouldn't need it.
its work thanks for the help
