My starter on my 307 grinds while cranking.
It had no shims to start (bought it that way) I put in a 1/32" shim straight across and it sounded worse. I took that shim out and put in 1/32" outside. It sounded better. I put in another 1/32" on the outside and it sounded better, but not perfect. I put in a 1/64" also on the outside and it sounded worse. I was close to perfect, but can still here a little grinding. What should I do?
