Hi fellow chevy fans,
I have a question concerning a chevy high torque starter motor.
What are the numbers on the case for a high torque starter???????
I am aware that a long post from the larger body which connects to the field?, or is a ground? is on it but will the case # help out or is it just a myth about the long bolt, I dought it a myth but will ask anyway.
I have a # which is, heck all the info from the hsg.
Delco-Remy USA
1108495 2B17 1
HELP ME PLEASE!!!!!
Thanks to all who reply.
dragginjohn
AKA
The Elkyman
what year,engine, trans, auto? man.? the high torque starters were used on all big blocks and high hp 350cu usually the 4 bolt blocks, let me know and I might be able to give you the correct part # for your car and maybe some one who has one thanks, Marty
shooter, I do not know if they fit chevy either they have different part# my book only goes to 1972 but the Olds 70,71 455 high toqure starters # 1108389 the pont.70 400,455 #1108435,71,72 400,455 #1108446, seperate #1108436 showing for the 72 455? I have a 70 396 4 speed it takes part #1108418 the same engine with the auto trans uses 1108430 one has a aluminum nose one has a cast iron nose are you looking for a date coded correct part# or just looking for a replacement starter? Marty
