I just noticed this after I got exhaust on the car today. Upon start-up and intermitantly at idle I have this loud squeal (almost sounds like a loose belt) at the REAR of the motor. Oil pressure is good at 50 psi. Car was on a slight downhill angle (towards the front) while I put the exhaust on. Noise seemed to get slightly better when warmed up but not much. I backed the car into the level garage and noise pretty much went away. I checked my tranny fluid and it was way low.( I guess more leaked out then I thought when I put the motor back in). I put what little fluid I had left in, about 1 1/4 bottles. Went out about 30-40 minutes later and started it up and the noise was back again. It definatley sounds like it is coming from the converter area. It is a brand new Edge converter and I took great care when I applied it to the transmission, and then bolted it up to the motor. I felt all the little "bumps" you are supposed to feel and had to move the converter up about 3/4" to the flexplate to bolt in on. So I am sure I installed it properly.
I haven't had the car on the road yet, but it goes into gear easily and moved forward and reverse with no problems. If I rev it up, the noise dissappears but then comes back on and off when at idle. Again, it did seem to go away when the car was warm and on a FLAT surface. Even after I added the extra fluid, it still barley reads on the dipstick. Before I started the motor for the first time I did fill the tranny fluid up to the "full" line on the dipsick. I do remember the squeal then too, but with open headers in was not nearly as noticable. First thing tomorrow after work I plan to fill the tranny all the way up and see if that helps, although I thought that the car just wouldn't move or shift well if fluid was low, not make a squealing noise. Any ideas? thanks
