1 - 8 of 8 Posts
Since my engine has square ports and manifold,low end torque is bad. I just ordered a new Edelbrock round port manifold.Hopefully Car should take off much better and since I am a traffic light to traffic light racer,should serve me well. Do you think this is wise to do?
I'd post your entire combination including trans, converter, and rear gears. Although oval port heads will build more bottom end torque than rectangulars, thats no reason why your car shouldn't be able to disintegrate the tires with the big port heads, if matched correctly with a good team of parts.
Lifetime Founding Member
I don't think the oval port intake will work with rect port heads. The top of the oval port intake is shorter than the port in the head. When installed, I think you'll see a portion of the head port exposed. Rect port intakes will work with oval port heads (I have this myself) but not vice versa.
von '69 300 Dlx SS TC #15 ACES #1575
My '69 SS
Please oh please use the search function for more answers. I beg of you, I BESEECH you.
Seriously though, if you click on search and follow the dialog boxes you will be suprised by what you can find.
Better Late than Never Fred
Team Chevelle #400
ACES #4055
I'd rather have a bottle in front of me, than a frontal lobotomy.
1970 Chevelle Malibu
Sure!
And while you have the intake off, pull those heads and throw on a set of oval ports to match the manifold. Keep your square jobbies in case you want to build an rpm/HP motor.
You don't even need the bigger valves. The oval port heads with the 2.125 and 1.7 valves make more torque than you can imagine.
Well, almost that much.
<BLOCKQUOTE>quote:</font><HR>Originally posted by Riffers70:
I BESEECH you.
<HR></BLOCKQUOTE>
O.K. ,I checked out the archives. I'm new here, you needn't curse.
Myles Turner, the "odometer rollback specialist"
"The difference between Men and Boys are the price of their toys"
1970 SS 396 TH400
1 - 8 of 8 Posts
