1 - 8 of 8 Posts
I know this is going to sound a bit lame, but I just put 14 years and 40-50K miles on a set of valve springs before thinking they should be changed. Maybe I knew they should've been changed earlier, but I procrastinated. The car hadn't been revving up as fast and lost .3-.4 at the track. I have an sbc with a HR with about 0.630 lift. I have an crappy spring tester that showed about 20-30 lbs low at the installed height, but more like 80-100 lbs low at 0.6 lift. I put a set of new springs in and the car is going through the rpms just like I remember when this engine got swapped in.
I made the job harder than needed by using a spring compressor that does 2 valves at the same time. It was a painful process to get this tool lined up to allow the keepers to get where they needed to be. I probably should've worn safety glasses for those flying keepers! Next time I'm going back to the 1-at-a-time tool. Anyone have any suggestions for an on-the-head tool that works good? I'm thinking this would be a great winter project for anyone else who might be good at procrastinating.
proform
summit
there all basically the same. you'll start bending the generic ones once springs pressures are around 550-650 lbs open.
that said if your running bigger springs and have a welder, just make your own at this point.
Yeah my son's in the same boat as he has my old SR 406. It probably needed springs before I ran the times in my sig as I beat the hell out of my tires for 2/3 years prior to going to Englishtown.
Now I just have to tell him to put away for springs AND lifters.
It's always nice to feel the difference when you changed something.
I did mine on the car a couple winters ago using the one that screws on the rocker stud.
That tool had its issues too, because it didnt seem to always compress the spring evenly -- it got compressed more on the side closest to the stud, so it was a little finnecky at times. I also used nylon rope into the spark plug hole (after rotating that piston to TDC) so that I wouldn't have to remove my header for the compressed air fitting. YMMV.
-Dave
I like the Lisle #17650 on head spring compressor. And a machinists scribe with magnetic tip for those locks.
I saw the LSM tool. Looks like their universal version has a bunch of adjustments to match different setups. Pretty cool.
1 - 8 of 8 Posts
