1 - 13 of 13 Posts
I have a 70 chevelle that i'm restoring and i have the console out to recondition. it's brown and i want it black and i'm not sure want kind of paint to use (vinyl paint or not). any help would be appreciated.
I've used low gloss black engine enamel to paint non black consoles..comes out mint and doesn't flake off.Just clean it thouroughly and lightly scuff it with red scotch brite pad.
1970 Chevelle SS396/M21/4.10 My 70 SS396
Engine pic
1970 Chevelle SS454My 70 SS454
1968 Oldsmobile Cutlass convertible
1982 Oldsmobile Cutlass 350 Olds,TH350(daily driver)
Chris Corwel,TC Member 785
for that hard plastic use 1)detergent and water then 2)sem-15 "sand free" plastic prep and 3)black laquer (pro color)
Use SEM sandfree then sem Plastic & Vynal Landau Black.... spray the paint on while the sandfree is still wet..2 light coats and it will be perfect..
I don't know about using engine paint on plastics.. you may be taking a chance, especially on a black object that has a wide thermal gradient..JMO..
Jody Sirmans
71 SS454
ACES
<BLOCKQUOTE>quote:</font><HR>Originally posted by JodySirmans:
<HR></BLOCKQUOTE>
I painted my console 4 years ago with engine paint..still looks MINT..and I've painted several other consoles black with the same paint.I've also painted them with SEM vinyl dye with Sand Free...they look the same,and durability is not an issue with either one,especially with the engine paint.
Discussion Starter #6
<HR></BLOCKQUOTE>Thanks for the tip.
Discussion Starter #7
Thanks for the advise. <BLOCKQUOTE>quote:</font><HR>Originally posted by leeds:
for that hard plastic use 1)detergent and water then 2)sem-15 "sand free" plastic prep and 3)black laquer (pro color) <HR></BLOCKQUOTE>
Discussion Starter #8
thanks for the advise. <BLOCKQUOTE>quote:</font><HR>Originally posted by mr 4 speed:
<HR></BLOCKQUOTE>
Discussion Starter #9
<HR></BLOCKQUOTE>
Discussion Starter #10
thanks for the advise. <BLOCKQUOTE>quote:</font><HR>Originally posted by leeds:
Discussion Starter #11
thanks for the advise. <BLOCKQUOTE>quote:</font><HR>Originally posted by JodySirmans:
<HR></BLOCKQUOTE>
I used the SEM vinyl dye and it turned out great. I even re-did my dash housing. I used SEM cleaner and then the plastic (or vinyl) prep. Just apply the dye in light coats.
Discussion Starter #13
<BLOCKQUOTE>quote:</font><HR>Originally posted by 1Quik7D:
I used the SEM vinyl dye and it turned out great. I even re-did my dash housing. I used SEM cleaner and then the plastic (or vinyl) prep. Just apply the dye in light coats.<HR></BLOCKQUOTE>thanks for the advise. i appreciate it.
1 - 13 of 13 Posts
