I’m changing out front spindles on my 67 and do not want to damage ball joints or boots. Is there another way besides the pickle fork or can you use the fork without damage???
BFH against portion of the spindle that lower ball joint passes through. Should deform it enough momentarily to release the ball joint. Keep a Jack underneath the lower A arm. Lots of pressure stored in that spring. (Almost lost a finger when I was in high school)
Where do I hit it, on the spindle itself?I never use a pickle fork or any other specialized tools, just a hammer. A couple of well placed solid whacks and they separate.
On top of the old one where my finger is pointing?
No... hit right on opposite sode of where your finger is. Outside of where balljoint goes through spindle. on the side. Directly where your hammer face is looking..On top of the old one where my finger is pointing?
Got it, hopefully leaving the shock in will keep the spring from flying out also. I have a spring compressor but was told I didn’t need it if I wasn’t replacing springs jus use Jack and leave shock in.No... hit right on opposite sode of where your finger is. Outside of where balljoint goes through spindle. on the side. Directly where your hammer face is looking..Good luck.
Leave ball joint nut on to where top of nut is at top of ball joint and smack the spindle.. Sometimes they pop loose slowly sometimes immediatly. so be prepared just in case something lets loose unexpectedly and violently
Look petty simple...ThanksI could not find a picture of an abody spindle, but here is where you need to hit it. Here is a short video to get the idea. BTW I've never had to use direct contact on a tie rod end, hitting on the side always works.
Okay, this project is complete, everything went well. Shocks, spindles, rotors, calipers in 3 hours👍It also needs some attitude when you hit, so get mad, think of old boss or something like that. Now is the time to use that Ford transmission hammer! Pickle fork is used where you will not be reusing the old parts.
