Original 1964 Malibu SS Speedometer. My Speedometer makes a "chickt-chickt-chikt" noise after about mile or so of driving usually starts around 30-40mph then gets considerably worst acting up as low as speeds at 20mph. It only makes the noise when the cable is attached. The noise also tends to go away if I let off the gas, which is really weird. My understanding is if you unplug the cable and the noise goes away it's not the cable making the noise. The needle doesn't bounce or act erractic at all, just a fairly loud noise.
I pulled the speedo and completely disassembled it and found nothing unusual. I greased the three gears that spin the odometer and reassembled. I benched tested it by sticking a power drill into the cable connection and it didn't make the "chickt" noise so I thought I was good to go. I installed the gauge back in and sure enough, the noise is back.
Could the noise only be from the combination of both the cable and speedometer as a pair? If the speedometer doesn't do it on its own(bench test) and the cable doesn't do it on its own(unplugged from speedo) all I can think of is there's some sort of connection issue between the two that drives the noise.
Maybe I could remove the speedo cable from the trans and make a jig that will interlace with the cable and spin it with a power drill?
