1 - 9 of 9 Posts
You should have put the speedo gears out of the old trans into the new trans. Can you still put your hands on the old trans?
The noisy speedo could be the cable needs to be replaced. The cable in my old Caprice has started making a racket since the weather got real cold.
Did you put BOTH of the gears from the old trans into the new one? There is the drive gear on the tail shaft, you have to take off the tailshaft housing, and the driven gear just inside of where the cable hooks up.
1 - 9 of 9 Posts
