Lifetime Founding Member
Can someone tell me the proper routing of the speedo cable on a '69 4 sp from the floor to the trans? A '70 assembly manual looks like it goes under the front of the trans, then back on the pass. side to the tailhousing. von
My 70 has the cable coming out and down, at about 45deg, of the rt side, then it curves back up and goes over the top and on up to where it enters the firewall.
Tom Parsons
Might look at the floorpan on pass side just beside the front of the trans. Might be a metal clip welded to the floor that bends around the cable. This will fix the routing. tom
Thanks for the replys. No clips are present. The floor pan was replaced by a previous owner. von
Von, my 69 has a metal clip that goes around the cable and is bolted/screwed to the floor pan. I'm sure it's the original setup.
Team Chevelle Gold #33
ACES Member #02913
Chevelle Club of Michigan
Livonia, Michigan
