1 - 20 of 26 Posts
hey all i been told that the sparks plug shields were to be installed on my 1970 396 ss in the day, i also remember the shields would short out the plug, we would take them off for that reason should i install them again for judging.
1970 SS454 LS6 11 second street car
Those shields do not belong on a big block Chevelle...not factory installed. Along with the cowl grilles and "caution:fan" sticker you see on a lot of incorrectly detailed cars.
Probably part of GM's "Planned Obsolescence " strategy, all the leaves and crap would fall in there, get washed down inside the fenders and rust them thru. The fenders on my 70 LS-6 lasted 3 years before having to be repaired, I believe this was the first year for GM using "reprocessed" steel for their bodies and the process was not yet perfected on making "reprocessed steel", so RUST came easily. FWIW.....Spark plug shields, i believe were shown in the assembly manuals for early C-2 Corvettes (1965 ?) attached to the metallic spark plug shielding so you could listen to your new Delco radio, without plug noise, while cruising in your NEW C-2. I've never seen them, just in the assembly manual pictures.
Good to know. I was just looking at a Chevelle at a car show Sunday that had the cowl grilles and I started to wonder if maybe I lost them when I had my car apart 10yrs ago.
Did they come on Malibu's or were they always an aftermarket item?
I think they may have been factory on another GM "A" body car line...ie Buick, Pontiac or Olds...I'm sure someone will correct me if I'm wrong
Rochester, New York
That makes sense to me. Seems like every Chevelle I see at cruise nights has them, so it must have been the thing to do back then. I remember scrounging thru the junkyards back then just to see what was available, too.
Along these same lines - I see a lot of people adding chrome pedal trim on all 3 Chevelle foot pedals. IIRC, that wasn't Chevelle factory either.
There are rubber seals on both sides of those openings to keep debris out.
Oldsmobiles, Buicks, and Pontiacs used a mesh screen. Kind of like a screen door screen.
nope. Always been an incorrect aftermarket part
1 - 20 of 26 Posts
