David,
I purchased an inexpensive short spark plug socket with a hex head for a 3/4 open/box end wrench. It was just short enough for me to slide it on with my fingers and then "fish" in the box end of the wrench over and commence turning it in small increments.
My problem was getting to the number six (6) plug, I could either look at it or touch it but not both. My regular spark plug "T" handle wrench would not fit and the deep 5/8 socket would not clear either.
I trashed a couple of inexpensive sockets by shortining them to the point that the plug was hanging out of both ends of the socket but then could not engineer a way of rotating the socket. Eastmans has 1/4, 3/8, and 1/2 drive plugs square on one end to plug into the socket and hex on the other end to put a wrench on but this too would not fit.
I have toyed with the idea of purchasing an inexpensive off set box end wrench, cut it off to make a "shorty" wrench and then cut a gap like a flair nut wrench to slide over the spark plug insolator so you don't have to clear the wrench over the end of the plug.
You see the off set box end should fit down in the cast well of where the spark plug hole is in the head - but I haven't gotten around to doing it. If you try that let us know how it worked.
John
