Looks good! I am working on mine in that same area. Have some rust holes to cut and patch up. Are the rockers now completely sealed? I was thinking if you get any water in there may want to drill some small weep holes in the bottom where you cant see to let out moisture/water if it gets in there. just a thought... :)
Thanks. Yes, completely sealed from the cowl. They have slots in them already (aftermarket floorpan/rockers) so it should drain if need be.
