71 chevelle 350/270hp, at/ps/ac
I have a small leak of at fluid that looks like it is coming from the rt front corner of the transmission pan. All bolts (13) were able to be tightened up 1/2 to 3/4 of a turn.
I got got a repleacement gasket ( rubber) and have the two following questions.
Should I use any type of sealeant on both side of the gasket ( trans housing and pan)? In the old days all I used was permetex, now I am not sure.
About how many qts of trans fluid will leak out when I replace the gasket? Just to not want to over spend and buy to many qts.
