I'm assembling a 350 for my son's Chevelle and have run across something I think may be incorrect. I want to make sure this is right before proceeding.
When setting the pickup tube height off of the bottom of the oil pan, the pickup assembly is angled up from the bottom of the pan. I expected the screen to sit somewhat level with the bottom of the pan.
I'm installing a HV oil pump with a pressed in pick up assembly (don't recall the brand off hand as it was purchased long ago and the box has been thrown away). I *may* still have the box the pickup assembly came in (will check when I get home).
Are the standard and HV pump different dimensions (using different pickup tubes)? I'm thinking that the HV pump is sitting deeper in the pan. This would require a change in the angle of the pickup tube, right? Do I have a HV pump and a standard pickup tube?
Thanks in advance for any info on this!
Tom
Tom
