I have been noticing a mild shutter that lasts for about 1/2 second when leaving from a dead stop. This only seems to happen after about 5 miles or so of driving when it gets warmed up. If I quickly give it about 1/3 travel of the gas pedal and put a load on the drivetrain, I can feel a shutter which feels like it may be coming from the rear end, but I'm really not sure exactly where it's coming from. If I were to take off normally, there is no problem. The transmission, torque converter and rear end have less than 3,000 miles on them. I don't think that it would be driveshaft related, because it doesn't happen until I drive it a bit and everything gets warmed up. I broke in the new ring and pinion just like the shop advised, changing the fluid and refilling it per their instructions. Posi additive was also used. I am just baffled. Could the transmission be the culprit? I just thought I would throw this out in the forum to see if anyone knows what might be going on, or how I may be able to diagnose the problem.
Steve
Steve
