hello all, i am new to your site. i have been over at the camaro site for awhile. my dad has a 64 chevelle conv [almost done] and a friend of mine is working on a 67 chevelle. well i have a question regarding the 67. it's a 67 chevelle malibu 283 # matching car.the question i have is we are seeing some 67 with a spacer type shroud between the radiator support and radiator.i am familar with this on the 64. but had not seen it on a 67 till today.my friend's does not have this is it suppose to???? his car does have a/c factory.i told him maybe a/c cars don't suppose to have it or maybe they stopped using it in mid year, just don't know can you chevelle guru's help us out here?? thanks
Administrator
It is actually a spacer. The small block cars had them to bring the radiator closer to the fan. The 6 cyl and BB cars did not have them. If converting to the long pump with a small block it will need to be removed. I'm not sure when it was discontinued, but I know they used them in 64 & 65. Philip
My 67 has this spacer for its 283, so it was definately around in 67. Maybe it depended on the type of fan, I've got a solid
4-blade. I bet AC cars came with clutch fans which would extend toward the radiator more, eliminating the need for the spacer.
Rob
Now: 67 Malibu 4-door
283/PG
In 5 years: 69 COPO/427
I think your right Rob, SB w/AC had clutch fan and bigger rad. and no spacer.
Brett
'67
SS396
clone
