I'm in the processe of removing my electric fuel pump and gas lines back to an original mechanical fuel pump. I believe the original fuel line from the tank to the fuel pump is still there. Should I replace it with a new one or could I run some gas through it to see if its' usable?
Thanks,
Fred
In Memoriam
you could test it. is it 5/16" or 3/8"?
In Memoriam
cap one end with a 3/8" vacuum and a hose clamp. use a my-t-vac or some similar hand vacuum pump to draw a vacuum in the line, see how long it holds.
