Should I change body bushings before full floor pan replacement?
1372 4
I have a 67 and was wondering if I should change the body mount rubber bushings first before I replace the floor pans. I will replace the full floor pans?(corrosion ain't it a B*&^#)
Thanks In Advance!
John Corbin Member #313
67' Chevelle Malibu Sleeper(Someday):)
San Antonio, Texas
I want the body to be as strong as possible before I pull it off the frame, so I'm thinking I'll replace the floor pans and trunk floor first. Maybe I'm just being paranoid.
Jeff Schramm
'65 300 Deluxe (L6)
Member #283
You'll definitely want to replace the bushings. After 32 years of weight on them I'm sure that they've got to be no good.
1970 Chevy Custom El Camino aka Kaileigh
Green Mist & Silver w/Green Vinyl Top
350ci/300HP 4bbl & Factory Dual Exhaust
Non-SS with Factory Rallies!
TH-350 Automatic - 2.73 Posi Rear
My El Camino Home Page - www.dreamelectric.com
Since rust is your problem I'll bet that those body bolts won't come off easy so the time to get at these demons will be when your old floor is cutaway. Don't mistake a rotating bolt head for a rotating bolt - I twisted the heads off two bolts off what was a rust-free convertible.
You should do the bushings one side at a time or you'll be re-aligning the body to the frame and it isn't fun.
