I have gathered the resources to now modify my 12 bolt housing to fit in my 78 Elky. There is a local shop that can shorten my housing to 52.5 inches. From what I see in the Moser catalog I can use their new axle housing ends and retainers instead of a C-clip eliminator because I will have to use new axles. Any recommendations or sources (I'm located in MD) other than Moser?
Also, I can install the lower control arm and shock mount from a 78 10 bolt so I'm not concerned with lower control arm alignment but I am concerned with upper control arm mounting and alignment. Are the housing upper mounts on a 12 bolt different than a late model 10 bolt? I think I want the uppers to be adjustable. Should I install no-hop bars and will they give me the proper alignment? What do you recommend for a Posi unit? I will want a new drive shaft and Moser makes several different ones I need a recommendation here too.
This might help answer the questions above. 1978 Elky w/ all GM LS7 w/ 4 speed. I have a very lofty goal of running high 11s with the AC on and this might require some later engine and trans mods. Just trying to smarten up from all the experience on Chevelle Tech before I make the calls tomorrow. Sorry for such a lengthy post. TIA. MikEC
