can anyone help me with shimming my starter. the teeth on the flexplate are shewed at the ends. does this mean I should use half a shim on the outside bolt? should I use two shims? thanx
Justin
Jason
I got this method from a real starter store (the guy rebuilds them for a living). This is from memory but I think I have it right.
With the starter installed and tight, the teeth on the starter gear should be 1/8 inch from the flywheel teeth. You can measure this with a 1/8 in drill bit. If it is too tight, add a full shim. If it is too loose add 1/2 of a shim to the outside bolt only. You may have to add more shims or 1/2 shims to get it right.
Also if the flywheel is too chewed up you may have to change it. It worked for me first time, hope it helps you.
Rick Schaefer
72 El Camino
TPI 350/700r4
Aces #00140
TEAM CHEVELLE #00038
NCOA #16197
[This message has been edited by rick (edited 08-11-99).]
Wow, Dean, thanks. That is a great thing to have in my big book of info.
