1 - 2 of 2 Posts
the cable hooks to your carb and provides a downshift to second or low depending on which gear you are in and vehicle speed. the cable attaches to the bottom of the carb linkage . if your trans wont shift i would check for vaccum at the modulator on the pass. side rear of the trans. also check the governor, located on the driver side under the round cover at the rear. these will either have the valve inside it stuck or the plastic drive gear will be damaged. hope this helps out
1 - 2 of 2 Posts
