Issue with my 65 El Camino is really frustrating. I recently installed a fresh built L79 engine. Flywheel was resurfaced by machine shop and new clutch assembly was balanced by the same machine shop. Also fresh rebuilt 65 M20 transmission. rebuild of trans included a rebuilt kit, new hub assemblies, sliders and synchronizers from D&L Transmission.
I have a stock Muncie shifter on the transmission.
I have adjusted the clutch to specs from the service manual. I made a shifter neutral gate tool/gauge that fits the shifter neutral gate nice and tight and have checked and/or adjusted the rods more that a couple of time.
Now to my issue. When I first start out for a drive, everything is fine. Shifting through all the gears is fine; however, after driving for 20 to 30 minutes and everything is warmed up, shifting from 3/4 down to 2nd or 1st is very difficult. Coming up to a light and down shifting from 4th to 3rd, no problem, then trying to go from 3rd to 2nd many times is near impossible. It is not an issue of gears grinding, just will not go into gear. Most of the time I can finally get it into gear by going back up and down. Also, if I pull into a parking lot and attempt to back up, several times reverse really grinds, even if I am able to go back into 2nd then try reverse again, a lot of grinding.
On two occasions, The transmission has actually gotten stuck in a gear. I stopped to get gas and put the car into reverse will filling up. When I restarted the car and shifted out of reverse I must have gone into 2nd gear. I could not get it out of 2nd and drove 25 miles home in 2nd. I put the car up on my lift and using a set of channel locks I flipped the shifter lever on the transmission 2/3 fork back to neutral. No resistance at all, it just easily when back to neutral.
Yesterday I was out for a drive and stopped at a local Home Depot to pick something up. I pulled into the parking lot and was having the normal issue of down shifting to 2/3, some how the transmission got stuck in 4th gear. No matter what I did with the shifter handle I could not get it out of 4th. Engine running or not, made no difference.
So I when into the Home Depot, bought a channel lock, crawled under the car and popped the shift lever back into neutral. No effort at all, just when right into neutral. No further problem driving home.
Some of what I have done is I spoke to Larry at D&L Transmission to see if he though I could have screwed anything up doing the transmission rebuild, and his opinion is no.
I have adjusted the clutch fork to beyond the service manual spec and now have it very close to the through out bearing. My thinking was maybe the clutch was not fully disengaging.
I certainly would appreciate any comments if someone has had any similar issue and managed to figure out what is wrong.
Thanks,
Don
Thanks,
Don
