Some of you may have read my other post in other sections. I'm now close to getting the 66' running fine.
Question: How can I adjust or change my shift points on my stock 200-4R? Valve body? Torque Converter?
It's a stock rebuilt trans (don't think it's from a GNX). I built my motor as a mild street but mostly stock engine (i.e. stock valve train on Vortec heads, mild cam with hydraulic lifters).
When I stomp on the pedal I can go all the way past 6000 rpm. WHOA! that scares the crap out of me. I don't need to be revving that high before it shifts. So now I have to feather the gas so the shift points come in earlier.
I should note that i'm a relative n00b when it comes to Automatics. I don't even know what "stall speed" means although I have tried to research it unsuccessfully.
