I have question as to the best way to set up the initial timing. I understand that you get the #1 piston on the compression stroke and turn the motor to the TDC spot on the balancer then drop in the distributor. Some people before dropping in the distributor turn the balancer to somewhere between 10 and 12 on balancer.
Question: Which is better? This has me somewhat confused. Will turning the initial timing to 12 before dropping the distributor in allow the distributor to have more turning radius for timing? I know that may sound dumb, so I do not know if I wording that correct.
