Did initial startup and cam break in on fresh 496 yesterday for 20 min. After break in, let it idle for a while and then did a couple blips of the throttle. At the end I had a strange noise come from the rear of the engine and the motor bogged a little. I had my buddy shut the engine off. Decided to start it back up and oil pressure was great and it sounded great....smooth idle and quick throttle response. Did hear a constant clicking noise under drivers side valve cover and a crack or pop coming from the drivers side exhaust pipe. Decided to run the valves today to hopefully cure my problem. I am not very experienced with setting the preload on the hydraulic valves and have a question.
I am rotating the push rod until I feel some resistance, then am turning the adjusting nut 1/2 turn (180 deg). When I turn the nut 1/2 turn, I can look at the valve spring and see that the valve is opening. Shouldn't the pushrod be compressing the lifter? Whats wrong?
Thanks a lot
Thanks a lot
