I'm building a 454 from the ground up. CompCam .552 lift, new hyd lifters, roller rockers, new push rods, new Edelbrock heads.
I set the number 1 cylinder TDC and set the lash on the reccomended intake and exhaust valves. I turn the crank 360 deg. so piston 6 is TDC. Then I set the reccomended intake and exhaust valves.
Here's my cituation. With # 1 at TDC, intake roller rockers on 3 & 4 are extremely loose & exhaust rockers on 5 & 7 are loose. With 6 at TDC, intake rocker on 2 is loose and exhaust on 4 is loose.
Any suggestions? Comments?
Thanks in advance for any assistance any one can offer.
