Finally found an original set of belts to replace the generic ones (right color and date code - score!). Anyway how are the front lap belts routed from the floor to the top of the bench seat? The generic ones came from the floor up over the bottom seat frame and under the seatback. This doesn't look right. Do they feed up under the bench somehow?
Do the belts come off the floor up thru the bottom of the bench? I can't find any holes in the bottom but I believe the seat has been recovered at one point. Right now if I fold the seat back foward you can see the belts coming off the floor and up over the frame. I don't believe that is correct.
