1 - 12 of 12 Posts
Hard drive fixed computer working great all down loads from MS done,Norton installed and updated,Reinstalled Firefox Then a plug in adapter for firefox from Adobe NOW it started doning this!
Screen goes blank........Beep......beep......beep.......beep,Cant turn it off I have to hold the button until it shuts off,And continues when I turn it back on if I tap on the case and retry it starts fine, But it doing it 6 times so far and seams to be running slow now.
Windows XP
HP 850 system
I did down load the "see whats running program" How do I use this program and what can I turn offf to increase my speed
Try taking out your memory, cleaning off the dust, and blow out the contacts on the mother board. Re-seat everything and try again. Sounds like your computer is giving off a error code.
Do you get any text on the screen?
Big D
I have been to the HP web site and saw they have a BEEP codes also but its not like code,Just like a alarm clock....x....x....x....x, No specific "code like" tone or length,Or is that what its suppost to be?
Big D
No, Not getting any error codes or text on screen,Just pops to black, But I will watch for one.
sounds a lot like a heat problem. Or the temperature diod isnt properly hitting the CPU. I know mine did this because of the diod problem.
Its only done it once when it was on all day, Its mostly when I start it in the morning, BUT I did have one heat sink that fell off and has been sitting in the bottom for who knows how long,I did fix that well it was apart.
I did also clean and blow out everything with my air compressor, How do I find the "temp diod". And I will pull and reseat all plug ins.
what was the heatsink for?
beeping still sounds like a beep code... it'll repeat itself over and over.
This is my first computer repair, NEWBIE :eek:
I really dont know what the heatsink was for, it was on something about 1 1/2 Sqd, I only noticed it by the goo on the back of the sink on the goo on the surface of the unit.
Next time it beeps I will count and listen for any veryations in sound.
I did have a code pop up this morning, First time I have seen this one.
TRAP 000000005=========EXCEPTION========================
TR=0028 CRO=800000011 CR2=000000000 CR3=00039000
gdt limit=0FF base=003F00 idt limit=o7FF base=0003F4000
CS:eip=0008:00405FF7 SS:ESP=0010:00060DD8 errorcode=000
flags=00010046 No Cy Zr Intdis Down trap Dis
EAX=00000 Ebx=000000 exc=0000000 edx000000004a ds=0010 es00010
ep1=00431a23 esi=00060e8c edp=00060 ddc cr0=80000011 fs=003 gs=00
I did pull and push all connections this morning and the windows came up differnt "Classic style" but I did not change them?
count the exact beep codes and look them up for your bios. It depends on whether it is a software vs hardware beep but it appears to be a hardware beep. Might be the video card if your using a pci or agp variety. Your mother board manufacturer should be able to give all beep codes and there meaning.
1 - 12 of 12 Posts
