We have put a small block into my dad's '81 4X4 Datsun truck and have always had a miss/hard time starting when cold, and I wanted to make sure we have the ignition system wired correctly. I thought maybe we had to many volts getting to the points/condensor and ruining the condensor. I drew a schematic in paint of how its wired...
I have the plugs gap'd @ .035", I have cleanded them several times, I have cleaned the points numerous times and gapped them to .016", bought a new condensor for the distributor, changed to an Accel Super coil, it has new plug wires that also have the correct resistance. I have changed the distributor cap and rotor. The timing curve is good with 12* initial, full manifold vacccum that raises it to 29*, and 43* while cruising(36* total. A while ago I did a test where I turned the key to the on position and opened the points with a screw driver, and they sparked which wasn't supposed to happen, the condensor was supposed to absorb the energy, could that be the problem somehow? Any info appreciated!
You will still have some arcing on the points even with a capacitor in there. That's why points need to be replaced due to pitting. Think that was the question.
Well I bought a new balast resistor for it tonight and stuck it on. I'll find out if that was the problem when he goes to start it tomorro morning in the cold.
