check for power at the tailight connector. You should have 2 wires one should be brown and the other yellow. The yellow wire is the
brake light\turn signal wire. Also make sure
the connector ground tab is making good contact. Also are you certain the bulb is
good? If your just examining it with your
eye it might still be failing. Sometimes
the filament is broken but wont separate
until it get hot.
best regards
Importtech
68 chevelle
my webpage
Dad's Place
