My father recently bought a very nice El Camino SS with a new crate ZZ502. The motor has been in the car for about 9 months and has about 1500 miles on it. We've been tuning on it for the few weekends since we got it and can't get it to idle as smoothly as we think it should. It has good fire to all cylinders, good clean new plugs, timing is best at 9-10 degrees initial (anything above 11 initial will cause pinging under load). This motor seems to like manifold vacuum to the vacuum advance (idles rougher with ported vacuum) and we've checked for vacuum leaks. It makes about 11-12 inches of vacuum at idle (850 rpm). We've dialed the idle screws on the primaries with gauge attached till we found the best idle/vacuum at about 1 1/4 turns out. It is not a true double pumper so no secondary fuel mixture to adjust. I've tried opening the secondary blades in the back barrels a little to see if a little more airflow at idle was needed. Our primary throttle blades are in the correct position with the transfer slot just at the top of the blade at idle. I've set both the float levels to the bottom edge of the site screw threads. We've got a Holley red electric fuel pump that never starves the car under any load, no return line though I don't think the Holley red is supposed to need one. Carb is what appears to be a new Holley 850cfm 4150 so I'm assuming the power valve is the newer kind that won't blow out after a backfire, but maybe thats a bad assumption. The cam is a stock ZZ502 roller with 224/234 and a 110 lsa so, while we're not expecting dead smooth idle, that cam should be pretty mild, especially for a roller cam in a 500+ cube motor. Cam was installed straight up from the factory and has not been changed according to the previous owner. The motor runs great at any speed above 1000 rpm and has no apparent valvetrain adjustment problems. (have not done a compression test yet though) It just seems to have a near miss at idle that is different than the lope of a cam with a lot of overlap. It's more like a small miss every second or so. Any ideas on what the more likely suspects would be to try next are appreciated. I have a perfect working Holley 750cfm on my GTO and I can swap it on temporarily just to see if the carb is the problem. The fact that this 502 runs so well at all other rpm's keeps making me think it is likely the carb. Thanks for any ideas, Rick
