I need some help here.... I have a 350 that I never had any problems with the idle. I went to start it last week and it kinda backfired and then took alot of turns to get started, kinda like it was flooded. Now it start up but runs rough. Above 2500rpm it sounds smooth. WHAT COULD IT BE? Does this sound like an intake leak?
Recap here is what I have done already..
1-Replace plugs and gap. All original plugs looked good.
2-Check and ohm wires
3-Replace cap
4-verify spark per MSD instructions
5-Compresson test GOOD
6-Check timing and verify 15* inital and 36* total. My old specs didn't change.
6-Remove all vac lines on manifold and plug. Same on carb.
8-Vac suction test. Tape up breather cap hole and put paper over pcv hole. The paper did not suck in. It was kind of blowing out.
9-Hand over the car. It killed the car and didn't notice any increase in RPM.
10-Replace power valve.
11-Adjust rockers
12-Adjusted air/fuel mixture screws
13-Disconnected tach lead from MSD
14-Verified all MSD wires were clear of any power wires or coil.
15-Carb cleaner spray test around intake and carb
16-No funny noises that I hear except a fluttering vac on manifold port
17-No dripping from carb booster venturiis
As you can see I'm trying all my options before I pull the intake. Is there ANYTHING else you can think of before I pull it?
3-Replace cap
11-Adjust rockers
