Easy questions, this is my first attempt at painting so sorry about the dumb questions.
The paint I am using has a 10-15 minute flash time between coats, do i have to disassemble the paint gun and clean it between every coat of the same type (base, clear, primer); or is it ok to let the gun sit that long without being sprayed????
Secondly, I realize there is going to be orange peel to be wet sanded away. Do I have to wet sand the base coat before I put clear on? or can i just put all my coats on and then wet sand the clear??
Thirdly, I am looking for a good gun for a beginner for around $100, any recommendations??
Thanks,
Thanks,
