Just installed a set of roller tip rocker arms from Comp Cam (PN# 1411-16). Got them installed with new springs, retainers, locks, etc. I did use the stock push rods as they looked great for reuse.
The problem (not sure if this is a problem) is that I am getting some noise from the drive train after the roller tips were installed. Since the roller tip rockers were installed, I've adjusted the valves, so that has been eliminated as a potential issue. Is this noise normal from the roller tip rockers?
Thanks in advance for chiming in guys!
