Trying to complete an essentially stock SBC 350 truck engine.
Plain old stamped rockers, original pushrods, Summit heads.
Most of the rockers appear well centered at the valve stem but a few are clearly off-center, No, 8 intake visibly moves sideways.
Some do not seem to retain adjustment.
Adjusted carefully, spin engine over, rockers are loose at TDC.
Adjusted them three times and decided I need to figure out the issue.
New cam so need to run it in before trying any sort of running adjustment, which I despise anyway as it's a hot oil mess.
My El Camino 327 will get solid lifters but this is a truck and real PITA to get at once installed so has to be hydraulic.
I used a drill and priming tool before attempting adjustment.
Left bank gets lots of oil out of the rockers but right bank sees very little.
If I have to pull the intake again now is better than later.
Suggestions please.
Suggestions please.
