OK Guys,
I got the Comp Cams rocker arm conversion installed. First of all, Olds should have done this to begin with! The kit itself was a 100% bolt on swap. The pushrods were the right length for my engine. The instructions are weak, just very general. No torque specs for the new studs, so based on small journal Chevy rod bolts (which are the same size) I torqued the studs 40-45. The installation had its moments. To change out the 2 rear pushrods on the left side required taking the brake booster loose (not off) and pull it over to the left a little. To change the 2 right rear pushrods the right motor mount bolt had to be removed and the right side of the engine jacked because the AC box was in the way (motor mount bolt was very easy to get out and back in). Took about 4hrs, open hood to test drive. I took my time.
