Fellas -
I'm building a road race engine and it's time to pick the camshaft. I'm new to road racing, so could use a bit of advice here.
Car is a 1971 Javelin AMX (sorry for the non-Chevrolet content!). The plan is to keep the car street legal (barely) and race it in the NASA American Iron series. Should weigh about 3,200 pounds with driver. Trans is a T-10 close ratio (2.23 first), 9" rear with a 3.50 gear. Engine is a .030 401 that's been balanced. Forged crank, rods, and pistons. Aluminum flywheel. 9.8:1 compression (a little lower than I would like, but can live with it). Stock Edelbrock aluminum heads. Single plane intake (Torker) with a Holley (have a few to choose from; thinking 750 DP or something like that). Max rpm is going to be 6,500 or so. Headers and 3" exhaust. Plan to run a solid flat tappet cam. Edelbrock says no higher than .580 lift with their springs. Manual brakes, so no need to worry about vacuum. Not worried about idle quality, either.
Guess my first question is what do folks look for in a road race cam? I'm thinking that a nice flat torque curve would be nice, with hp up to 6,500 or so. Problem I see is that a wide LC (112?) will give me a flat torque curve and a tight LC (106?) will give me more max torque and increase my cylinder pressure, which I think will help with my somewhat low compression. Think a larger cam with a wide LC will be lazy with 9.8:1. Figure I will be making around 450 hp with the right cam.
Here are a few grinds that I think are in the ballpark:
Comp has a solid flat tappet cam that may be a bit too big - it's the 290B6 or 10-601-5 Hi Tech. 255/266 @ .050, .576/.570, 106 LC. RPM range of 3800-6800 sounds about right. I'm right at the limit with the stock springs here, too.
Crane has a solid that's a bit smaller - #861201, 238/248 @ .050, .512/.533, 112 LC.
Crane PowerMax #861241 sounds good except for the wide LC - 248/258 @ .050, .533/.555, 112 LC.
I like the Comp Hi Tech with the 106 LC, but it may be a bit too big. I can also get something custom ground for not too much $.
Your thoughts?
Thanks,
Scott
Your thoughts?
Thanks,
Scott
