Hi Chevelle friends,
I have a 1967 Chevelle SS 396 cu. in. BB. While up on the lift changing oil my neighbor mechanic noticed the engine right side exhaust manifold hitting the frame. We noticed the engine mount hole is elongated. So, we loosened the bolt, moved the engine higher and re-tightened the bolt. Now there is maybe 1/4 " clearance from manifold to frame.
Is this a valid fix? Will engine torque push the engine down again on the frame? We did notice the engine mount bolts are not grade 8 (hardened).
Any advice is appreciated.
John
John
