Are the ridges that form at the top of your cylenders just carbon build up or are they the cylender wall itself and when the piston rings wear down the cylender the ridges form?
Ryan
The ridges Are where your pistons have worn down the cylinders itself, and not had enought travel to wear the ridge down. This is common in High mileage motors. They make a Cylinder Ridge Cutter to take care of it.
350 TBI EFI 4speed 12bolt 3.73's
Bench Blue w/black inter. [email protected]
"UNACCEPTABLE!!!!!" Beldar
My 69 Chevelle
Technically it's where the "rings" stop traveling in the cylinder. Cutting tool is called a "Ridge reemer".
The pistons are tough to get out if this ridge is very pronounced.
This tool is expensive to purchase but you can rent it inexpensively for a one time deal.
FastSS396man
69' SS396 Chevelle
L78 396/375hp
M-21 Close Ratio
10 year Resto
It's brand new again!
