1 - 18 of 18 Posts
High All,
Anyone used one of these in their chevelle?
any modes to tunnel or floor pan?
any issues with trans?
your thoughts on these transmission in general.
Wes,
I have a Richmond Street 5sp in my Cutlass. I installed it 22yrs ago and it's still doing just fine. Since you are in OKC, you are welcome and look at the installation.
Well, the Richmond Super Street has several advantages. If one already has a Muncie them most of the stuff can be reused such as shifter, bell housing, clutch and pressure plate and even the driveshaft. A new rear yoke is required. There are no tunnel mods needed. They have been around for a while so used units are available.
I have a Legend and had to wait a little bit to aquire it but during the wait I was looking for a Super Street and just missed a time or two as they were already sold by the time I found out. Not positive but think the 5th gear is available in two different ratios.
The shifters will not interchange.Muncie is a 4 speed and the Richmond is a 5 speed,2 completely different shifters.
There may also be differences with the clutch/pressure plate.I believe the Muncie is a 10 spline and the Richmond is a 26 spline.
Guy
Guy, you are correct. Different shifter and a new disc would be needed as it a 26 spline.
There is a video out by Paul from 5speeds that refers to some mods done to the super street to make it a smoother shifter.
I guess the big thing is its an option for those that dont want to cut their trans tunnel.
Reactions: GuysMonteSS
How does the Super Street 5 speed compare to the old 4+1 as far as case size and other differences? I know the Super Street is overdrive and has a higher torque rating. The transmission Paul was working on was a 4+1.
Brad,it's actually a 2 part video.I had my transmission guy watch them last time the last time the old Doug Nash was rebuilt,and it made a huge difference in how well it shifted.
Guy
Super Moderator
So, I could drop a Richmond 5 in the '65 wagon without modifying the floor pan, the shifter location, could reuse my crossmember, clutch, bellhousing and driveshaft (already have a 26-spline clutch)?
One of the biggest reasons I haven't put in an overdrive trans yet is because I didn't want to hack up the floors or muck with moving the console around. Also, all the additional equipment to install a Tremec is kind of a turn off even though I really like the Tremecs. I have one in the '06 GTO which has been great. Heavy as a mofo, but works great once you get a good shifter on it.
I'd think their 2.89 first gear version would be okay with my stupid 4.10 gears. And I could always change the rear end gears at some point (they are kind of fun).
Rich, I put one ( Richmond 4+1) in my 65. No hacking floor, moved crossmember back one hole ( had to drill 2 new holes), Turbo 400 yoke is needed and the driveshaft needed to be shortened about 3/4" (roughly) I have 3.08s in the rear, but could easily go 2.73 or 2.56 as my 1st gear is 3.27 and 5th is 1-1.
Discussion Starter #10
Wes,
Tom, I would love to come visit about it sometime.
I was thinking about going to this next weekend if life & the boss allow.
El Reno Fly-in & Community Day
August 22nd, 2020 9:00 AM
Join us at our First Annual "Fly RQO Fly-In and Community Day!" We will celebrate the airport's recent improvements while showcasing one of our biggest projects to date. This will be a day full of food, vendors, WWII-era warbird flyovers, classic cars, and much more. Come join the fun!
I run a 4+1 in a '66 Malibu, 327/350hp or so with 2.73 rear gears....love it. A little notchy but nothing obnoxious. Also run a Richmond SuperStreet 5 speed with unknown gears but overdrive, in a '66 SS blown bbc….shifting is more more buttery but very precise. That car has a McLeod RXT clutch and love everything about it. If I had my choice, it would have 3.73 butt gears, but not complaining. No hacking on either car.
With our old Richmond road race 5 speed, I had to slightly clearance the tunnel for the 3/4 ( forward) shift rod is all. It relocated the shifter back a freckle, , so I had to make plastic "extensions". Underneath, I can t say if the modern one is like the old one i had , but we literally took a crossmember for a t400 , cut the trans mount off, flipped it upside down and welded it back up. Finally the Richmond 5 Speed relocates the trans mount back a bit, only as much as the next set of hole already predrilled in the frame rail in our 67.
Reactions: RR24
Going to go pick up a new Richmond Super Street 5 speed today. We'll see how it goes. Installing in a 66 Malibu.
I thought that might be a good option for me, and then I saw the price...... As much as I would like to have an overdrive tranny, I could drive my car for the next 100 years and not save enough gas to justify the expense of all of these 5 and 6 speed transmissions.
Initial observations.
1. Same length as Muncie. 22 inches bell housing face to end of output shaft
2. Shifter is 4 inches further back than a Muncie and appears to stick a lot further up. (came with a Long brand shifter) Have to cut on the tunnel I believe.
3. Muncie has about 6 inches of spline on the output shaft. Richmond 3 1/2 inches. Guessing with higher spline count it does not need as much spline?
4. Picked up body mount kit to install prior to installing this transmission. Read on here I believe to make sure body mounts are in good shape?
For sure #4. Prior owner cheated and only replaced lower bushings. Our 67 could use another 1/2" of height. Hence my having to clearance for the 3/4 rod and a bit of safety loop fitment issue.
Now I get to play again. :( Hey, the undercoat removal is the big job, raising the car one side at a time to get new upper bushings in ought be child's play in compariosn.
Well gentlemen, I've decided that I'm not going to cut / disassemble this car again (just put it together). Maybe some time down the road. Sold the 5 speed to another guy putting a 66 together. New Auto Gear M22 ordered.
1 - 18 of 18 Posts
