I have a 71 Chevelle that had a standard transmission and now has an automatic turbo 400. I need to know what color the wires are under the dash for the reverse lights. I want to be able to mechanically turn the switch on by turning the column. What are the purple and the purple/black wire for? They are tied together so I was guessing that they were some kind of neutral safty switch.
Thanks for your help,
Scott [email protected]
1971 SS 454 Coupe, 1971 Mailbu Convertible
Scott,
The backup light wires should still be hooked up to the switch on the lower part of the column. There was a backdrive linkage attached to the transmission linkage and to the steering column that would activate the backup light switch. Unless the wires are connected to the new shifter (B&M?) or the original style horseshoe, it should be workable now. My car is the same way, but I am converting back to the 4-speed. You wouldn't happen to have the clutch pedal nuetral switch?
