1969 4 speed chevelle, Can't find the switch that turns on the reverse lights. Following the wiring diagram, I chased the correct wire up to the stearing column but the previous owner has disconnected it.(I knew that its the correct wire, cause I tested it.) The diagram doesn't show where it suppose to go. Doesn't make sense to me that it plugs into the stearing column without any wiring to the trans.
Any input would be a great help.
