The cable from the column to the shift indicator is missing. Also, part of the shift arrow where the cable attaches is broken. I have been unable to locate anyone that sells replacement parts for this. Anyone know of a source?
69 chevelle - 2 speed
So when I did this on our '70, I couldn't find anyone either.
I finally took the broken one and fabbed up the wire and it's guide using some plastic from a bondo spreader with a hole drilled in it. Glued that to the frame of the broken indicator and ran a wire thru it to the clip.
Florist wire works darn good.
When I was done, I received an email from a guy with a salvage yard in the South East, and he had an intact one that I wound up buing, but the repaired one also would have worked fine. Can't see it once it's in, so the "originality" wouldn't have been an issue IMHO...
If you don't find one, you might try repairing yours.
-curt
Fixed mine with a lure cable that i got from academy.Have a ragged out one from a 68 but the needle,cable,and return spring is good.Don't know if will interchange.Got a real good one from red's auto in troup,tx.Suppose to have over 300 chevelles there he pulls parts off.On mine the cable will start sawing into the plastic after awhile,bad design.
