For all those more "experienced" body techs.. Would you mind reviewing my plan of action... TIA
1. Adjust Decklid/Door to proper spec
2. Replace Rear Seat Pan
3. Replace Floors
4. Replace Deck Filler Panel
5. Patch RH Quarter
6. Remove LH 1/4
7. Remove outer/inner wells
8. Position both wells to fit
9. Position 1/4 to proper fit.
10. Remove 1/4, weld in Wells.
11. Weld on 1/4
The positioning would use sheet metal screws so I would have a guide to go about when put the 1/4 back on..
Thanks,
Todd
3. Replace Floors
5. Patch RH Quarter
6. Remove LH 1/4
11. Weld on 1/4
Thanks,
Todd
