i've got a slightly enlarged lower control arm hole at the drivers side frame mounting brackets.
i was chasing a weird vibration/oscillation;
this only happened while under hard acceleration with tires grabbing and slipping.
the inside end of the mounting bolt is tied into the brace attached to the upper control arm bolt.
the outer mounting point where bolt goes thru boxed section of frame is where it needs attention...
do i just cut the boxed area open and weld a reinforcement plate in;
and then close up the boxed area on the outer part of the frame??
anyone else have the same issues???
